Ai FAQs
Filter results by:
You're viewing All FAQs
- How To Fix Firewall or Antivirus Blocking Avolites Software
- When I start Ai on my laptop with external screens connected, the software freezes.
- Can I use Adobe software to render the AiM codec?
- How do I get the best performance from the AiM codec?
- Multi-touch screen calibration required after updating to V16.0
- How do i encode my media files using the AiM codec?
- Do I need to Activate/Authenticate my new Ai AvoKey?
- Which screen resolutions can I use?
- Can the Ai AvoKey be used with Ai v10.3 and below?
- Which format effects can i use?
- Where do I find the serial number of my AvoKey
- I’ve installed Ai but it doesnt seem to run when I click the icon.
- When I run Ai the screen is black.
- How do I get live feeds into Ai?
- Are the Operating System and Software 64 bit?
- Is the system based on the DXV codec used by UVA and Resolume and is it Intraframe or Mpeg based?
- Can 3d objects be imported and textured?
- Can I make new screen shapes?
- Which 3d Model formats can I use in Ai?
- Can I use audio in Ai?
- What is the best audio format for Ai?
- Can I use Notch in Ai?
- Can I quickly recall states in Ai?
- Can my edgeblending be done in Ai?
- Can I warp my output to fit my screens?
- Can I use external controllers with Ai?
- Do I need an Avolites console to control Ai?
- My screens are in the wrong order.
- What are the minimum requirements to run Ai?
- What are the delays on the video input cards?
- The software works with OpenGL, will specialised cards like the Quadro range help the performance?
- Will CUDA be used for certain effects?
- What are the main ways to control Ai?
- Which graphics settings should I use for Windows 7 or 8?
- Which graphics settings should I use for Windows 10?
- My MIDI controller doesn't work properly with Ai?
- What are the recommended graphics card drivers for Ai?
- What are the recommended capture card drivers for Ai?
- Why can’t I run Titan on my Pearl 2010?
- Do I need a touch wing for my Expert?
- How do I connect my external monitor?
- What can I do if my console is stolen?
- Avolites media servers and Novastar LED processors
- How do I update the existing fixture(s) in my show file to the latest personality?
- Can my old Ai licence key be used to run v11?
- How do i authenticate my new Avokey for Ai?
- I have plugged in my USB licence key but Ai is still in trial mode.
- Cleaning the dust cover for my console
- Send video to a flat screen
- Setup for mapping with a projector
- Send video to a multi part LED screen
- Send colour information to a lighting fixture
- Change the output layout
- Use Timecode in Ai
- Connect Ai and Titan using CITP
- Assign A Midi Controller
- Import project assets
- Use Live Camera Feeds in Ai
- Use Notch blocks in Ai
- Improve Ai performance
- Connect Ai and Titan using Synergy
- What is the best video format for Ai?
- What are the differences between the Ai Licence levels?
- When I run Ai it says "Cannot find a Salvation Licence"
- Does Avolites Support Pathway's Secure Streaming ACN (ssACN) Protocol?
- When I start Titan, the software is stuck on a grey screen with a pulsing console logo. How do I get past this?
- Why are my fixtures not responding when changing attributes in the programmer or when firing a playback?
- My Titan One dongle is flashing Orange (RX). How do I change this to flash Green (TX)?
- My Titan One dongle is continuously flashing green and orange. How do I resolve this?
- My Titan dongle is overheating/not working. What does this mean?
When submitting a license request, I am presented with submission failed. How do I
resolve this? - The audio waveform is not visible in the Pioneer DJ workspace when using CDJ3000s. How do I fix this?
I want to connect an external touch screen monitor, how can I check to see whether it is
compatible? - How do I use an external display with the console?
- How do I set/change my consoles IP Address?
- How can I move my show file(s) to another computer or console?
- Can I load a show file from a newer version of Titan into an older version?
- I have two separate show files, is it possible to combine both shows together?
- Why am I unable to find my fixture in the personality list?
- How do I import custom or requested personalities?
- Why are the faders on my console not behaving as normal?
- I’m presented with ‘Dongle not found’. How do I resolve this?
- How do I get into System?
- Why does my external display mirror the console display?
- The time and date keeps changing on my console. How do I resolve this?
- I am unable to view patched fixtures in the internal visualiser. How do I resolve this?
When I open the Capture Visualiser workspace, I am presented with the following
‘Capture Library Not Installed’. How do I resolve this? - I don’t have a personality for my LED Parcan, help!
- What does Locate do?
- Is there a colour picker on Titan?
- Error In Capture Component
- What is Ai?
- Which video formats can Ai play?
- The bottom right rotary pot next to the display on the Diamond 9 does not respond in Titan. How do I fix this?
- What is the AiM codec?
- Covid-19 Cleaning Advice
- Reaper Import does not connect to Titan. How do I resolve this?
- When using WinAmp and Titan, the Timecode is out of sync. How do I fix this?
- When using Astera Titan Tubes on my Quartz desk, there is a DMX delay. How do I fix this?
- I have exchanged my fixture (with cells) with another fixture that has more cells. When I reload the show I lose control of the extra cells. How do I fix this?
- My ‘Fixture/Node’ is behaving unexpectedly when using Artnet. How do I fix this?
- Titan Remote FAQs
- What is Ai?
