Downloads (Current Version)
If you are updating from a software version below Titan V15.0, you need to perform the v15.0 recovery before upgrading.
Arena v15.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required.
AvoKey must be plugged in before upgrading. |
Download 466.0MB |
Arena v15.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Download 2.4 MB 08/10/2019 |
Documentation
Go to Online Manual |
Go to Release Notes |
Go to the Recovery Creator Guide |
Arena v15.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 271.7 MB |
Arena v14.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 183.8 MB |
Arena v13.0 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 183.8 MB 06/02/2020 |
Arena v12.1 Upgrade Installer | This is an upgrade installer: – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 171.0 MB 11/12/2019 |
Arena v12.0 Recovery Creator | This is a recovery installer: – To downgrade to previous versions, please see release notes. ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Arena v11.4 Upgrade Installer | AvoKey not required | Download 110.4 MB 20/08/2019 |
Arena v11.3 Upgrade Installer | AvoKey not required | Download 110.3 MB 18/04/2019 |
Arena v11.1 Update Installer | This is an upgrade installer: – Faster install and simpler install experience, allow 2 hours – Does not normally require relicensing. – Does not include additional performance increases from the recovery installer. |
AvoKey not required | Download 110.2 MB 17/08/2018 |
Arena v11.1 Recovery Creator | This is a recovery installer: – Improvements to performance, recomended for large shows – Longer and more complex install process, allow 48 hours ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files will be deleted, user backup of show files required. ⚠ Only one historical software version maintained |
AvoKey not required | Download 2.4 MB 26/09/2018 |
Arena v11.0 Recovery Creator | AvoKey not required | Download 3.2GB 02/05/2018 |
Arena v11.0 Upgrade Installer | AvoKey not required | Download 109.1 MB 08/05/2017 |
Older Downloads
Arena v10.1 Upgrade Installer | AvoKey not required | Download 136.2 MB 24/03/2017 |
Arena v10.0 Recovery Creator | AvoKey not required | Download 2.7 GB 11/06/2016 |
Arena v9.1 Recovery Creator | AvoKey not required | Download 2.7 GB 28/09/2015 |
ECNs
Code | Title | Download |
ECN-0209 | Arena and TT2 Wing Firmware | Download |
Arena (Fujitsu V1 Hardware) || AR-00001 – AR-00783 || Recovery Instructions
Please ensure that you have a backup of all important show files before proceeding.
- Shutdown the Arena console.
- Start up the console holding the Locate button to enter the boot selection menu.
- In the menu, press the And button until the UEFI: USB stick is highlighted.
- Press Enter to boot into the recovery stick.
Arena (Fujitsu/Kontron V2 Hardware) || AR-00784 – Onwards || Recovery Instructions
