Downloads (Current Versions)
Important Information: Tiger Touch II consoles between serial number TT-02001 and TT-03065 will require a hardware upgrade to run V16.0 and above.
Tiger Touch II v18.0 Upgrade Installer | – Upgrade consoles running v16.0 and 17.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 737.8 MB 10/04/2025 |
Tiger Touch II v18.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.3 MB 11/04/2025 |
Downloads (Previous Versions)
If you are updating from a software version below Titan V15.0, you need to perform the v15.0 recovery before upgrading.
Important Information: TT-02290 and below require V12.0 recovery, before upgrading to V15.1.
Tiger Touch II v17.1 Upgrade Installer | – Upgrade consoles running v16.0 and 17.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 670.7 MB 22/05/2024 |
Tiger Touch II v17.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.3 MB 18/03/2024 |
Tiger Touch II v17.0 Upgrade Installer | – Upgrade consoles running v16.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 670.5 MB 18/03/2024 |
Tiger Touch II v16.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.3 MB 06/12/2022 |
Tiger Touch v15.1 Upgrade Installer | – Upgrade consoles running v12.0 & v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 465.6 MB 08/03/2022 |
Tiger Touch II v15.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.3 MB 28/04/2021 |
Tiger Touch v15.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 271.3 MB 13/04/2021 |
Tiger Touch v14.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 250.6 MB 20/10/2020 |
Tiger Touch v13.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 183.4 MB 06/02/2020 |
Tiger Touch v12.1 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 170.6 MB 11/12/2019 |
Tiger Touch v12.0 Recovery Creator | – Upgrade consoles running v11.2 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 2.3 MB 08/10/2019 |
Tiger Touch v11.4 Upgrade Installer | – Upgrade consoles running v11.1 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Not required | Download 110.0 MB 20/08/2019 |
Tiger Touch v11.3 Upgrade Installer | – Upgrade consoles running v11.1 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Not required | Download 111.0 MB 18/04/2019 |
Tiger Touch v11.1 Recovery Creator | – Improvements to performance, recommended for large shows – Longer and more complex install process, allow 48 hours – Relicensing required, please allow 48 hours for upgrade. |
Not required | Download 2.3 MB 26/09/2018 |
Documentation
Go to Online Manual |
Go to Release Notes |
Go to the Recovery Creator Guide |
Go to Console Panel Firmware List |
Engineering Change Notice (ECN)
Name | Title | Download | |
ECN-0191 | Dongle Connection Point Change | Download | |
ECN-0193 | LCD Inverter Enable Delay | Download | |
ECN-0199 | DMC Touchscreen Controller Calibration | Download | |
ECN-0204 | LV-67H BIOS Update | Download | |
ECN-0209 | Arena & TT2 Wing Firmware | Download |
Tiger Touch (LV-677) || TT-00001 – TT-01212 || Recovery Instructions
Click here to view the legacy recovery guide
Tiger Touch Pro (LV-67H) || TT-01220 – TT-01615 || Recovery Instructions
Consoles with LV-67H motherboards will show a Phoenix SecureCore Tiano screen while booting up. For this motherboard you should ensure that the latest BIOS is installed, see ECN-0204 for details. Prior to version 11.1 the console will boot automatically into the recovery USB stick if it is connected. To run the v11.1 or later recovery you will be required to change your BIOS boot settings (Button presses for the Tiger Touch are shown in brackets):
- Use the up/down cursor keys (Through/And) to highlight the Boot Features option and press Enter.
- Use the up/down keys (Through/And) to highlight the UEFI Boot option and press Enter.
Tiger Touch Pro (Fujitsu V2 Hardware) || Recovery Instructions
- Shutdown the console.
Tiger Touch Pro (Fujitsu V3 Hardware) || Recovery Instructions
Tiger Touch II (LV-67H V1 Hardware) || TT-02006 – TT-03065 || Recovery Instructions
Tiger Touch II (Fujistu V2 Hardware) || TT-03066 – TT-04020 || Recovery Instructions
Tiger Touch II (Fujitsu/Kontron V3 Hardware) || TT-04020 – Onwards || Recovery Instructions
