Downloads (Current Versions)
Important Information: TNP-00136 and below require a hardware upgrade to run V16.0 and above.
TitanNet Processor v18.0 Upgrade Installer | – Upgrade consoles running v16.0 and v17.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 771.7 MB 10/04/2025 |
TitanNet Processor v18.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.4 MB 11/04/2025 |
Downloads (Previous Versions)
If you are updating from a software version below Titan V15.1, you need to perform the v15.1 recovery before upgrading.
TitanNet Processor v17.1 Upgrade Installer | – Upgrade consoles running v16.0 and v17.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 703.7 MB 22/05/2024 |
TitanNet Processor v17.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.4 MB 06/03/2024 |
TitanNet Processor v17.0 Upgrade Installer | – Upgrade consoles running v16.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 703.6 MB 06/03/2024 |
TitanNet Processor v16.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.4 MB 06/12/2022 |
TitanNet Processor v15.1 Upgrade Installer | – Upgrade consoles running v12.0 & v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 471.7 MB 08/03/2022 |
TitanNet Processor v15.0 Recovery Creator | – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. – Show files may be deleted, please backup first. |
Internal AvoKey required | Download 2.4 MB 28/04/2021 |
TitanNet Processor v15.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 276.7 MB 13/04/2021 |
TitanNet Processor v14.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 255.3 MB 20/10/2020 |
TitanNet Processor v13.0 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 190.2 MB 06/02/2020 |
TitanNet Processor v12.1 Upgrade Installer | – Upgrade consoles running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 177.2 MB 11/12/2019 |
TitanNet Processor v12.0 Recovery Creator | – Upgrade consoles running v11.2 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required | Download 2.4 MB 08/10/2019 |
TitanNet Processor v11.4 Upgrade Installer | – Upgrade consoles running v11.1 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Not required | Download 122.9 MB 20/08/2019 |
TitanNet Processor v11.3 Upgrade Installer | – Upgrade consoles running v11.1 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Not required | Download 122.8 MB 18/04/2019 |
TitanNet Processor v11.1 Recovery Creator | – Improvements to performance, recommended for large shows – Longer and more complex install process, allow 48 hours – Relicensing required, please allow 48 hours for upgrade. |
Not required | Download 2.4 MB 26/09/2018 |
Documentation
Go to Online Manual |
Go to Release Notes |
Go to the Recovery Creator Guide |
Go to Console Panel Firmware List |
Engineering Change Notice (ECN)
Name | Title | Download | |
ECN-0204 | LV-67H BIOS Update | Download | |
ECN-0207 | TitanNet Processor Impedance Matched Ethernet | Download | |
ECN-0208 | TitanNet Processor Hyper Threading BIOS Settings Change | Download |
Titan Net Processor (LV-67H V1 Hardware) || TNP-00001 – TNP-00100 || Recovery Instructions
- Start up the console pressing Del on the keyboard to enter the BIOS.
- In the BIOS, press the right cursor key until the Advanced tab is displayed.
- Use the up/down cursor keys to highlight the Boot Configuration option and press Enter.
- Use the up/down keys to highlight the UEFI Boot option and press Enter.
- Press the F10 on the keyboard then Enter, to save changes.
Installing v11.1 or later for the first time changes the Boot Priority Order in the BIOS, if you need to run a recovery again you will need to carry out the following instructions:
- In the BIOS, press the right cursor key (@) until the Boot tab is displayed.
- Use the up/down cursor keys (Through/And) to highlight entries and the +/- keys (Include/Edit or Macro/Copy on original Tiger Touch key layout) to move entries up or down. The correct order should be as follows:
- USB HDD
- USB CD
- Windows Boot Manager
- ATA HDD0
- Now the console will boot automatically into the recovery stick if it is plugged in when the console is started.
Titan Net Processor (Fujitsu V2 Hardware) || TNP-00101 – TNP-00215 || Recovery Instructions
The TitanNet Processor will boot automatically into the recovery USB stick if it is connected. For other consoles to boot into the recovery stick follow these instructions:
- You will require a keyboard to follow these instructions.
- Shutdown the console.
Titan Net Processor (Fujitsu/Kontron V3 Hardware) || TNP-00216 – Onwards || Recovery Instructions
