Downloads (Current Version)
TitanNet Processor v15.1 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v15.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Internal AvoKey required. AvoKey must be plugged in before upgrading. |
Download 471.7 MB |
TitanNet Processor v15.0 Recovery Creator | This is a recovery installer: – Fixes occasional rendering issue while using internal Capture. – Longer and more complex install process, allow 48 hours. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Recovery Creator Guide
Download |
Documentation
Go to Online Manual |
Go to Release Notes |
TitanNet Processor v15.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 276.7 MB |
TitanNet Processor v14.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 255.3 MB |
TitanNet Processor v13.0 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 190.2 MB 06/02/2020 |
TitanNet Processor v12.1 Upgrade Installer | This is an upgrade installer: – Upgrade TNPs running v12.0 recovery. – Faster install and simpler install experience, allow 2 hours. – Does not require relicensing. |
Download 177.2 MB 11/12/2019 |
TitanNet Processor v12.0 Recovery Creator | This is a recovery installer: – To downgrade to previous versions, please see release notes. ⚠ Relicensing required, please allow 48 hours for upgrade. ⚠ Show files may be deleted, please backup first. ⚠ Only one historical software version maintained. |
Download |
TitanNet Processor v11.4 Upgrade Installer | AvoKey not required | Download 122.9 MB 20/08/2019 |
TitanNet Processor v11.3 Upgrade Installer | AvoKey not required | Download 122.8 MB 18/04/2019 |
TitanNet Processor v11.1 Upgrade Installer | This is an upgrade installer: – Faster install and simpler install experience, allow 2 hours – Does not normally require relicensing. – Does not include additional performance increases from the recovery installer. |
AvoKey not required | Download 122.7 MB 17/08/2018 |
TitanNet Processor v11.1 Recovery Creator | This is a recovery installer: – Improvements to performance, recomended for large shows – Longer and more complex install process, allow 48 hours ⚠Relicensing required, please allow 48 hours for upgrade. ⚠ Show files will be deleted, user backup of show files required. ⚠ Only one historical software version maintained |
Download 2.4 MB 26/09/2018 |
TitanNet Processor v11.0 Recovery Creator | FTP Download | Download 3.3 GB 02/05/2018 |
TitanNet Processor v11.0 Upgrade Installer | AvoKey not required | Download 121.6 MB 08/05/2018 |
Older Downloads
TitanNet Processor v10.1 Recovery Creator | FTP Download | Download 2.8 GB 03/04/2017 |
TitanNet Processor v10.0 Recovery Creator | FTP Download | Download 2.8 GB 12/06/2016 |
TitanNet Processor v9.1 Upgrade Installer | AvoKey not required | Download 92.7 MB 28/07/2015 |
TitanNet Processor v9.0 Recovery Creator | Download 2.3 GB 23/04/2015 |
TitanNet Processor v8.1 Upgrade Installer | AvoKey not required | Download 84.5 MB 10/12/2014 |
TitanNet Processor v8.0 Recovery Creator | Alternative Download | Download 2.4 MB 03/09/2014 |
TitanNet Processor v8.0 Upgrade Installer | AvoKey not required | Download 84.4 MB 26/08/2014 |
ECNs
Code | Title | Download |
ECN-0208 | Titan Net Processor Hyper threading BIOS setting change | |
ECN-0207 | Titan Net Processor Impedance Matched Ethernet | |
ECN-0204 | Fix – Failed to create bootable BIOS Stick! (Error: 2) | ECN 0204 – Windows 10.zip |
Titan Net Processor (LV-67H V1 Hardware) || TNP-00001 – TNP-00100 || Recovery Instructions
- Start up the console pressing Del on the keyboard to enter the BIOS.
- In the BIOS, press the right cursor key until the Advanced tab is displayed.
- Use the up/down cursor keys to highlight the Boot Configuration option and press Enter.
- Use the up/down keys to highlight the UEFI Boot option and press Enter.
- Press the F10 on the keyboard then Enter, to save changes.
Installing v11.1 or later for the first time changes the Boot Priority Order in the BIOS, if you need to run a recovery again you will need to carry out the following instructions:
- In the BIOS, press the right cursor key (@) until the Boot tab is displayed.
- Use the up/down cursor keys (Through/And) to highlight entries and the +/- keys (Include/Edit or Macro/Copy on original Tiger Touch key layout) to move entries up or down. The correct order should be as follows:
- USB HDD
- USB CD
- Windows Boot Manager
- ATA HDD0
- Now the console will boot automatically into the recovery stick if it is plugged in when the console is started.
- Titan Net Processor (Fujitsu V2 Hardware) || TNP-00101 – TNP-00215
Titan Net Processor (Fujitsu V2 Hardware) || TNP-00101 – TNP-00215 || Recovery Instructions
The TitanNet Processor will boot automatically into the recovery USB stick if it is connected. For other consoles to boot into the recovery stick follow these instructions:
- You will require a keyboard to follow these instructions.
- Shutdown the console.
Titan Net Processor (Fujitsu/Kontron V3 Hardware) || TNP-00216 – Onwards || Recovery Instructions
